А поймете ?
Model: MS-7235 PCB: 1.1 Author:
Old Version: W7235IMS.168
New Version: W7235IMS.169 Code Base: 02/02/06 Build Date: 09/27/06
Description for FAE:
1. Modified "save and exit CMOS setup utility" way when change Dram
timing value.
2. Modified memory voltage.
3. Fixed cannot use SCSI(promise card) card.
4. Updated Jmicro Rom.
5. Fixed some device(CDROM) string show abnormally in BIOS.
6. Removed the W7235IMS.168 solution.
Model: MS-7235 PCB: 1.1 Author: Melody Li
Old Version: W7235IMS.167
New Version: W7235IMS.168 Code Base: 02/02/06 Build Date: 09/25/06
1. Added Jmicron BIOS code( FUN0.AS_) to patch CD-ROM transfer mode
in PIO problem.
2. Added Option ROM (jmb361_v1.06.53_raid.bin) to patch low system
performance problem.
Model: MS-7235 PCB: 1.1 Author: Julia Xu
Old Version: W7235IMS.166
New Version: W7235IMS.167 Code Base: 02/02/06 Build Date: 09/08/06
1. Fixed suspend light work abnormally after resume from s1.
2. Fixed Power Loss function fail.
3. Fixed CPU(0F64h and 0F65h) Temperature show abnormally.
Old Version: W7235IMS.165
New Version: W7235IMS.166 Code Base: 02/02/06 Build Date: 09/07/06
1. Fixed Smart FAN failed after resume from S3.
Old Version: W7235IMS.164
New Version: W7235IMS.165 Code Base: 02/02/06 Build Date: 09/06/06
1. Fixed WHQL test fail.
Old Version: W7235IMS.163
New Version: W7235IMS.164 Code Base: 02/02/06 Build Date: 09/01/06
1. Modified the solution about fixed fail to resume from standby
(S3)with 4 x 1GB DDR533 or 667 memory installed.
Old Version: W7235IMS.162
New Version: W7235IMS.163 Code Base: 02/02/06 Build Date: 08/31/06
1. Fixed Intel self test issue.
2. Restored SSID SVID when Jmicro S3 resume without Jmicro RAID driver.
Old Version: W7235IMS.161
New Version: W7235IMS.162 Code Base: 02/02/06 Build Date: 08/30/06
1. Fixed fail to resume from standby (S3)with 4 x 1GB DDR533 or 667
memory installed.
Old Version: W7235IMS.150
New Version: W7235IMS.161 Code Base: 02/02/06 Build Date: 08/29/06
timing value.
2. Removed onboard VGA.
3. Fixed Jmicro S3 fail without Jmicro RAID driver.
4. Changed the ClockGen max range.
5. Fixed Intel self test issue.
6. Modified some item help string.
7. Fixed "Excute bit support" option string error.
8. Updated Award Code.
