У меняне чего не получилось вот что пишет
SPI FlashROM Programmer 2.17 (C) 2008-2013 by Martin Rehak; rayer@seznam.cz
Compiled by GCC 4.8.1 at 03:27:46, Oct 1 2013
(DOS/Win9x compatability)
SYNTAX: spipgm /<command> [filename] [address] [size] [/l=iobase] [/d=delay]
commands: i - identify SPI FlashROM
r address size - read & display data block (0x prefix=hexa number)
d filename - dump entire FlashROM to file
p filename - program entire FlashROM from file (without erase)
v filename - verify FlashROM content against file
e - erase entire FlashROM
eb address count - erase 64kB blocks from address (0x prefix=hexnum.)
b - blank check of entire FlashROM
u - unlock write protection bits (depends on WP# level)
s status - write status byte, manuf. specific (0x prefix=hexa number)
l=* - LPT port I/O base address (default is 378h - LPT1, 0x prefix..)
d=* - additional delay for SPI clock pulse width [usec] (default=0)
LPT to SPI pin assignment (compatible with BSD AVR programmer):
pin 7 = D5 -> CS#
pin 8 = D6 -> SCK (CLK)
pin 9 = D7 -> MOSI (DIO)
pin 10 = ACK -> MISO (DO)
pin 18 = GND -> GND
C:\DOCUME~1\Trundel>D:\SPIPGMW.EXE
Compiled by GCC 4.8.0 at 03:27:53, Oct 1 2013
(Win9x/NT/2K/XP compatability)
pin 7 = D5 -> CS#
pin 18 = GND -> GND
C:\DOCUME~1\Trundel>D:\SPIPGMW /p msi.rom
SPI connected to LPT port at I/O base address: 378h, SCK pulse width: t+0us
FlashROM JEDEC ID, type: FFFF00FFh - parity error!
unknown manufacturer, unknown chip
Enter total FlashROM size in kB:
