Автор Тема: Не обновляется ПО ( скриншоты внутри) NSIS error !!!  (Прочитано 3558 раз)
Boogi
  • Reputation Power: 14
  • Boogi пока не имеет никакого влияния.
Выскочило предложение об обновлении ПО видео карты (HD6850 Cyclon), но выскакивает ошибка вконце и ПО не обновляется.
Как исправить?
Просмотр:
http://pikucha.ru/iakH2
http://pikucha.ru/iakH3
http://pikucha.ru/iakH4
http://pikucha.ru/iakH5
  • Reputation Power: 20242
Ну и ? MSI то при чем ? Идите по указанной странице чтобы посмотреть что там не так с nsis .
А там как обычно
How do I fix the problem?
There are a number of ways the installer can be modified, but we'll cover steps to fix the problem on your end. If all these steps don't work, please contact the developers or publishers of the software you are attempting to install or your normal computer support channels.
If the software was obtained from the Internet
 1. Clear your browser's cache.
2. Disable any download accelerators or managers and download the installer again.
 3. Rename the installer so it is a simple one-word name with no special characters (without removing the .exe suffix) Example: install.exe
4. Download the installer from another source approved by the software developer or publisher. It might be corrupted on the server, or the connection to the server is unreliable from your location.
5. Update your anti-virus software (if installed) and download the installer again.
 6. Disable your anti-virus software and download the installer again.
7. Download the installer using another computer and copy it to the original computer.
 8. If you have the nVidia firewall installed, uninstall the program and download the installer again.
 9. Scan for, and remove malware and viruses on your system.
10. Scan the hard drive using scandisk, chkdsk, or any other hard drive repair tool.
 11. For people of ROMANIA who use FireFox in Romanian language try this tutorial: http://www.tutorialepc.ro/nsis-error-error-launching-installer-remediere-problema-2.html
« Последнее редактирование: 21 Февраль 13, 11:35:50 от Дмитрий Кучинский »
Толяны4
  • Noli nocere!
  • Reputation Power: 4553
  • Толяны4 вызывает восторг!Толяны4 вызывает восторг!Толяны4 вызывает восторг!Толяны4 вызывает восторг!Толяны4 вызывает восторг!Толяны4 вызывает восторг!Толяны4 вызывает восторг!Толяны4 вызывает восторг!Толяны4 вызывает восторг!Толяны4 вызывает восторг!Толяны4 вызывает восторг!Толяны4 вызывает восторг!
  • Не ошибается тот, кто ничего не делает.
Скачайте драйвер для х64 или х86 и установите вручную, предварительно удалив текущий драйвер.
MSI  GX60--AMD Trinity A10 4600M_&_AMD HD 7970M 2 Gb GDR5_&_4*2 Gb DDR3 1600 Mhz_&_128Gb SSD PLEXTOR PX-M5S +
500Gb HDD WDC_&_Windows 7 Ultimate x64 + Windows 8 Professional SL x64
Boogi
Модераторы, не помогает все та же ошибка
Толяны4
  • Noli nocere!
Возможно,  проблема с ОС
Для корректной работы всего советую не так обновлять дрова, а сперва читстить driver sweeper-ом, затем ставить вручную скачанные.
