Автор Тема: Обменяю i7-2670qm с доплатой на i7-2860qm или i7-2920mx!!!  (Прочитано 2894 раз)
kripke
  • Reputation Power: 7
  • kripke пока не имеет никакого влияния.
Обменяю рабочий i7-2670qm  с доплатой на i7-2860qm или i7-2920mx!!!
Процессору не больше недели.Заказывал на EBAY за  230баксов на замену 2630.
Данные процессора:
Intel Core i7-2670QM SR02N Processor 6M Cache, up to 3.10 GHz
Essentials
Status   Launched
Launch Date   Q4'11
Processor Number   i7-2670QM
# of Cores   4
# of Threads   8
Clock Speed   2.2 GHz
Max Turbo Frequency   3.1 GHz
Intel® Smart Cache   6 MB
Bus/Core Ratio   22
DMI   5 GT/s
Instruction Set   64-bit
Instruction Set Extensions   AVX
Embedded Options Available
   No
Lithography   32 nm
Max TDP   45 W
Memory Specifications
Max Memory Size (dependent on memory type)   32 GB
Memory Types   DDR3-1066/1333
# of Memory Channels   2
Max Memory Bandwidth   21.3 GB/s
ECC Memory Supported   No
Graphics Specifications
Processor Graphics   Intel® HD Graphics 3000
Graphics Base Frequency   650 MHz
Graphics Max Dynamic Frequency   1.1 GHz
Graphics Output   eDP/DP/HDMI/SDVO/CRT
Intel® Quick Sync Video   Yes
Intel® InTru™ 3D Technology   Yes
Intel® Insider™   Yes
Intel® Wireless Display   Yes
Intel® Flexible Display Interface (Intel® FDI)   Yes
Intel® Clear Video HD Technology   Yes
Dual Display Capable   Yes
Macrovision* License Required   No
# of Displays Supported   2
Expansion Options
PCI Express Revision   2.0
PCI Express Configurations   1x16, 2x8, 1x8 2x4
# of PCI Express Lanes   1
Package Specifications
Max CPU Configuration   1
TJUNCTION   100 C
Package Size   37.5mm x 37.5 (rPGA998)
Graphics and IMC Lithography   32 nm
Sockets Supported   FCPGA988
Low Halogen Options Available   See MDDS
Advanced Technologies
Intel® Turbo Boost Technology   2.0
Intel® vPro Technology   No
Intel® Hyper-Threading Technology
   Yes
Intel® Virtualization Technology (VT-x)
   Yes
Intel® Virtualization Technology for Directed I/O (VT-d)
   No
Intel® Trusted Execution Technology
   No
AES New Instructions
   Yes
Intel® 64
   Yes
Intel® Anti-Theft Technology   Yes
Intel® My WiFi Technology   Yes
4G WiMAX Wireless Technology   Yes
Idle States   Yes
Enhanced Intel SpeedStep® Technology
   Yes
Intel® Demand Based Switching   No
Thermal Monitoring Technologies   Yes
Intel® Fast Memory Access   Yes
Intel® Flex Memory Access   Yes
Execute Disable Bit   Yes
Intel® VT-x with Extended Page Tables (EPT)   Yes
пишите:
kripke@mail.ru
+79280425665
E6603
  • Reputation Power: 3497
  • E6603 вызывает восторг!E6603 вызывает восторг!E6603 вызывает восторг!E6603 вызывает восторг!E6603 вызывает восторг!E6603 вызывает восторг!E6603 вызывает восторг!E6603 вызывает восторг!E6603 вызывает восторг!E6603 вызывает восторг!E6603 вызывает восторг!E6603 вызывает восторг!
Могу продать 2920хм за 21000 рупий!
