Добрый день,решил увеличить объём памяти на своём ноутбуке.
Собственно вопрос,
сколько максимум можно установить на GX710 и какой максимум частоты??+ интересует ещё замена процессора на более мощный,какой лучше поставить вместо Туриона??
Processor
Number of cores 2 (max 2)
Number of threads 2 (max 2)
Name AMD Turion 64 X2 Mobile TL-58
Codename Tyler
Specification AMD Turion(tm) 64 X2 Mobile Technology TL-58
Package Socket S1 (638)
Technology 65 nm
Core Speed 1895.2 MHz
Multiplier x FSB 9.5 x 199.5 MHz
HT Link speed 798.0 MHz
Stock frequency 1900 MHz
Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, x86-64, AMD-V
L1 Data cache 2 x 64 KBytes, 2-way set associative, 64-byte line size
L1 Instruction cache 2 x 64 KBytes, 2-way set associative, 64-byte line size
L2 cache 2 x 512 KBytes, 16-way set associative, 64-byte line size
Chipset
Northbridge ATI RS690/RS690M rev. 00
Southbridge ATI SB600 rev. 00
Graphic Interface PCI-Express
PCI-E Link Width x16
PCI-E Max Link Width x16
Memory Type DDR2
Memory Size 2048 MBytes
Channels Dual
Memory Frequency 315.9 MHz (CPU/6)
CAS# latency (CL) 5.0
RAS# to CAS# delay (tRCD) 5
RAS# Precharge (tRP) 5
Cycle Time (tRAS) 15
Bank Cycle Time (tRC) 21
Command Rate (CR) 2T
Memory SPD
DIMM # 1
SMBus address 0x50
Memory type DDR2
Module format SO-DIMM
Manufacturer (ID) Transcend Information (7F4F000000000000)
Size 1024 MBytes
Max bandwidth PC2-5300 (333 MHz)
Part number TS128MSQ64V6J
Serial number 0007A722
Manufacturing date Week 26/Year 07
Number of banks 2
Data width 64 bits
Correction None
Nominal Voltage 1.80 Volts
EPP no
XMP no
JEDEC timings table CL-tRCD-tRP-tRAS-tRC @ frequency
JEDEC #1 3.0-3-3-9-12 @ 200 MHz
JEDEC #2 4.0-4-4-12-16 @ 266 MHz
JEDEC #3 5.0-5-5-15-20 @ 333 MHz
DIMM # 2
SMBus address 0x51
Memory type DDR2
Size 1024 MBytes
Number of banks 2
Data width 64 bits
Correction None
EPP no
XMP no
