Ingtar про Acer one правильно сказал- вариант с Windows должен быть солидней, правда на офф.сайте спецификация какая-то корявая, типа- догадайся сам: Таблица спецификаций
Operating System
Linpus(tm) Linux® Lite version
Platform
Intel® Atom(tm) processor N270 (1.60 GHz, 533 MHz FSB, 512 KB L2 cache)
Mobile Intel® 945GSE Express Chipset (DDR2 400/533 MHz)
Mobile Intel® 82801GBM Chipset
Acer InviLink(tm) 802.11b/g Wi-Fi CERTIFIED® network connection, supporting Acer SignalUp(tm) wireless technology
System memory
Single channel with onboard SDRAM and one soDIMM slot
DDR2 533 MHz SDRAM memory interface design
Onboard SDRAM: 512 MB
soDIMM slot: Supports 512MB/1 GB soDIMMs for total system memory of up to 1.5 GB
Display
8.9" WSVGA high-brightness (typical 180-nit) Acer CrystalBrite(tm) TFT LCD, 1024 x 600 pixel resolution
LED backlight
262,000 colors supported
Storage
NAND flash module or hard disk drive for internal storage
NAND flash module: 8GB
Hard disk drive: 2.5" 9.5mm 120 GB
Storage expansion: SD(tm) Card reader
Multi-in-1 card reader
Audio
High-definition audio support
Two built-in stereo speakers
MS-Sound compatible
Built-in digital microphone
Communication
Integrated Acer Crystal Eye webcam, supporting 0.3 megapixel resolution
WLAN: Acer InviLink(tm) 802.11b/g Wi-Fi CERTIFIED® network connection, supporting Acer SignalUp(tm) wireless technology
LAN: 10/100 Mbps Fast Ethernet
WWAN: UMTS/HSPA (High-Speed Packet Access) at 850/1900/2100 MHz and quad-band GSM/GPRS/EDGE (850/900/1800/1900 MHz), upgradeable to 7.2 Mb/s HSDPA and 2 Mb/s HSUPA (for 3G models)
Supports receiver diversity and equalizes at 2100 MHz
Dimensions and weight
249 (W) x 170 (D) x 29 (H) mm (9.8 x 6.7 x 1.14inches) for SKUs with NAND flash module and 3-cell battery pack
249 (W) x 195 (D) x 36 (H) mm (9.8 x 6.7 x 1.42inches) for SKUs with hard disk drive and 6-cell battery pack
995 g (2.19 lbs.) for SKUs with NAND flash module and 3-cell battery pack
1.26 kg (2.78 lbs.) for SKUs with hard disk drive and 6-cell battery pack
Color choices
Sapphire Blue
Seashell White
Golden Brown
Coral Pink
Power
30 W adapter with power cord
24 W 2200 mAh 3-cell Li-ion battery pack
57 W 2600 mAh 6-cell Li-ion battery pack
Up to 3-hour battery life for SKUS with 3-cell battery pack
Up to 7-hour battery life for SKUS with 6-cell battery pack - экран-?, батарея 6х-? и размер с 6х-? Ваще у меня АА 5115, но неудобно с ним, обычно его дома жена мучает
